16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Printing an A1 sheet
Hello,I have printed A1 and A3 Sheets with drawings at a scale 1:100 but the drawings are probably 5% smaller than 1:00, any suggestions? I couldnt find any Scale setting in the printing dialogue box Thanks in advanceGaston
If your sheet is set up properly then just print 100%.
Thank you, but what should I do to set up as a 100%?
Thanks again
G.
click on the big R
Click on print, when the next window opens up
click on print setup
then click on paper placement , and click on centre
then
under zoom click on zoom and make sure it says 100%
then click on ok
then you can click on print, then print
have fun
geoff
67 Posts No Rating |
printing from revit is not as smooth as printing from .pdf so I usually print to .pdf first, then I also have a record of what I printed.
Many thanks Mansell5 and Andy Benett, It works!!
G.
Printing sheet issues |
Sat, May 23, 2015 at 4:01:06 PM
printing sheet sets - only the sheets |
Wed, Jul 18, 2012 at 3:10:10 PM
Sheet Printing - Name of PDF |
Thu, Feb 26, 2015 at 10:07:34 AM
massing problem in printing |
Sun, Feb 14, 2010 at 7:36:21 AM
Vector Printing - Ceilings Disappear |
Wed, May 28, 2014 at 9:12:41 AM
