Forums >> Revit Building >> Technical Support >> Autodesk 360 Rendering - Adjust Exposure Problem
Fri, Mar 15, 2013 at 12:01:04 PM | Autodesk 360 Rendering - Adjust Exposure Problem
CbusArchi
I am currently running Revit 2013 but on a new machine, so everything is a fresh install (Google Chrome, drivers, GPU, etc.). The move to 2013 was also recent, so all my files are updated 2012 models. I have successfully used the 360 rendering for months now with the 2012 plugin, but recently the "Adjust Expsure" feature simply doesn't respond. It will load the screen but the image never appears (just the endless loading circle) and the adjustment sliders are frozen.
I have verified that my WebGL is installed, enabled, and working through Chrome. I even downloaded Firefox as a test, but the same issue persists. I know certain GPU's don't support WebGL, but my card isn't listed so it should be good (NVIDIA Quadro 4000). I also verified my Java and Flash, not knowing how the tool is built, but those are all current and enabled as well.
Is this a 2013 issue or a hardware issue? I'm open to any and all suggestions. Thanks!
Tue, Mar 19, 2013 at 9:17:32 AM | Autodesk 360 Rendering - Adjust Exposure Problem
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Have you installed the Service Pack Updates for 2013?
Tue, Mar 26, 2013 at 9:43:21 AM | Autodesk 360 Rendering - Adjust Exposure Problem
CbusArchi
Yes, Release 2 is installed [20121003_21185(x64)], but would that affect how the "Adjust Exposure" tool loads in the cloud?
Render materials OK in AutoDesk 360, not rendering in Revit
Mon, Nov 24, 2014 at 3:26:41 PM
Autodesk 360 cloud
Fri, Feb 22, 2013 at 11:21:56 AM
Daylight and Artificial light relationship
Wed, Aug 20, 2008 at 5:13:23 PM
Can't Remove File from BIM 360
Wed, Apr 10, 2019 at 8:59:16 AM
Uploading dwfx to Autodesk 360
Mon, Jun 30, 2014 at 3:50:48 AM
Page generation time: 2.5602
