Forums >> General Discussion >> Wishlist >> Toposurface point reporting
Fri, Mar 15, 2013 at 11:16:07 AM | Toposurface point reporting
mongopac
Currently, Toposurfaces only report their elevations using project points.  They do not report their elevations as survey points.  If you want to make a change to a point from a revised grading plan received from your civil engineer, you would need to take that revised survey point, translate it manually using a calculator, and input it into the toposurface as a project point.
Revit need to add an option to have the toposurface be able to toggle how it report its point,s giving the user the option of using survey points or project points.
Sun, Feb 2, 2014 at 2:18:35 PM | Toposurface point reporting
paolocasa1
paolocasa1 Avatar
5 Stars: 8 Votes
you could use this tool to retrieve a CSV file with the points of the topography and edit it in excel if you want http://puntorevit.blogspot.it/2014/01/topo-to-csv-external-command.html
Toposurface Elevation Base Point
Thu, Apr 28, 2016 at 4:35:51 PM
Toposurface level wrong to Co-ordinates
Tue, Mar 3, 2015 at 7:38:02 AM
Flat Toposurface
Thu, Aug 3, 2017 at 8:58:49 AM
Toposurface Outline
Mon, Jul 8, 2013 at 1:02:11 AM
Building and Toposurface relationship
Tue, Mar 27, 2012 at 7:03:56 PM
Page generation time: 0.2214
