Forums >> Revit Building >> Technical Support >> Can I turn a curtain panel system into one monolithic object
Fri, Mar 15, 2013 at 11:14:39 AM | Can I turn a curtain panel system into one monolithic object
xixiha
Not sure if it's possible. I need turn one entire curtain panel system into one monolithic piece, that means no differentiation between panels and mullion, it comes like one complicated but one piece object. Please let me know if there is a way to do this. I exported it to CAD, but they are still seperated into different object. Thanks!
Fri, Mar 15, 2013 at 12:15:02 PM | Can I turn a curtain panel system into one monolithic object
Remove the seperating grid section and it will be one panel.
Fri, Mar 15, 2013 at 1:47:16 PM | Can I turn a curtain panel system into one monolithic object
xixiha
I don't think you get me. what I need is object with grooved (change from mullion) surface, which define each panel. If I delete the grid, I loose both the groove and defined panels.
Sat, Mar 16, 2013 at 1:18:11 PM | xixiha
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting xixiha from 2013-03-15 13:47:16
I don't get it. You can create a panel that meets your needs and replace the existing panel with it.
Edited on: Sat, Mar 16, 2013 at 1:18:33 PM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Mar 18, 2013 at 10:54:41 AM | Can I turn a curtain panel system into one monolithic object
xixiha
I attached two images to show what I want
Mon, Mar 18, 2013 at 10:57:32 AM | Can I turn a curtain panel system into one monolithic object
xixiha
In our case, the mullion is resessed from the panel. I want to keep the complicated geometry for a rendering reason. I am looking for a way to transfer the original model(the left image) to something like in the one piece object(right image).
Any suggestion will be appreciated!
Mon, Mar 18, 2013 at 10:58:07 AM | Can I turn a curtain panel system into one monolithic object
Those images don't tell us anything.  Communicate!
Mon, Mar 18, 2013 at 1:03:10 PM | Can I turn a curtain panel system into one monolithic object
xixiha
Don't you notice the resessed mullion merged with the panels around it?  That's what I mean by 'one piece'.
Mon, Mar 18, 2013 at 1:59:26 PM | Can I turn a curtain panel system into one monolithic object
xixiha
I exported the revit model to 3DS, and then export back to CAD, seems it worked. But still hope some convinient way to do this.
Mon, Mar 18, 2013 at 5:29:33 PM | Can I turn a curtain panel system into one monolithic object
xixiha
Turned out the above way is still not working. Hope someone can give me a hand!
Tue, Mar 19, 2013 at 10:06:30 PM | Can I turn a curtain panel system into one monolithic object
xixiha
I attached two more images, hoping my intension can be understood. still struggling for this...
Curtain system panel problem
Tue, Jul 10, 2007 at 10:08:07 AM
Curtain system > glazing panel matherial
Mon, May 28, 2012 at 1:02:14 PM
missing empty curtain wall system panel
Thu, Aug 4, 2016 at 7:17:33 AM
curtain panel offset
Mon, Sep 1, 2014 at 4:30:14 PM
custom shape of curtain panel results in panel replacing
Mon, Apr 12, 2010 at 12:17:28 PM
Page generation time: 2.3970
