17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> show Vapor Barrier below the foundation slab
4 Posts No Rating |
Please share your ideas about showing vapor barrier below slab and grade beam in sections.
I have tried to add membrane layer for the slab but then a finish layer needs to be added below it with thickness and revit doesnt show membrane layer in section.
Thanks
4 Posts No Rating |
I am Using revit 2013
We don't model this layer at all. We use the traditional method of showing it - add a detail line ... sometimes a dashed line pulled off the face so it can be seen and noted.
4 Posts No Rating |
Thanks
so that means i have add detail lines in all the sections ?
43 Posts No Rating |
depends on what scale your sections are at, 1/50 we dont show it as its only ga section, at 1/20 1/10 1/5 yes but as a detail line offset from the surface
how do you show vapor/air barrier and membranes? |
Wed, Jun 10, 2015 at 2:59:27 PM
Footing joins to gravel, not slab |
Fri, Nov 6, 2009 at 6:07:20 PM
Slab Foundation Questions |
Fri, Mar 7, 2008 at 10:56:28 AM
Footings for Slab Foundation |
Tue, Oct 30, 2007 at 7:05:08 AM
Changing Linetypes in Foundation Plan |
Thu, Mar 18, 2010 at 7:18:01 AM
