Forums >> Revit Building >> Technical Support >> Sheet Parameter
Thu, Mar 14, 2013 at 5:10:22 PM | Sheet Parameter
rwood27
Hi,
I haven't done much with creating my own parameters.  I would like to create a text parameter for a titleblock that would indicate that a sheet is x number out of x.  NYC requires you have this on your drawings.  I would like to stop doing in manually and spend my time doing something else, like napping.
Thanks!
Fri, Mar 15, 2013 at 7:15:45 AM | Sheet Parameter
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Try this.  There are also other threads here to look at, search Sheet Counter
http://revitrocks.blogspot.com/2010/02/add-sheet-counter-to-revit-title-block.html
Numerate 'Sheet Number' parameter for match line family
Mon, Apr 28, 2014 at 10:17:51 AM
View List doesn't have parameter to show them in order of number on sheet?
Fri, Aug 26, 2016 at 2:48:10 PM
Editable Text on Sheet without shared Parameter (simple way)
Mon, Oct 27, 2014 at 3:38:10 PM
Filtering placeholder sheets by discipline in a sheet list
Thu, Jun 23, 2011 at 12:27:04 PM
Sheet / Drawing Index / List Check Box
Thu, Dec 18, 2008 at 8:48:15 AM
Page generation time: 2.6422
