18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> split surface - new toposurface disappears
2 Posts No Rating |
Using Revit Architecture 2012
Trying to split my main toposurface into smaller areas as I am creating paths that are built in a later phase setting. When I finish the splitting the new area I've created just disappears - a white hole in my green grass, not the tarmac I asked for. However the new surface does exist in other views.
This does not appear to be a phase issue as I've tried viewing my plan in all phases and it's still a hole. And the new toposurface is not just hidden in the plan view. Nor do I seem to be able to alter anything in the visibility / graphics override box that makes the path appear.
I tried copying my toposurface into a new model and it all worked fine. when i copied this back into my original model the problems recurred.
Thanks for any help
Lizzy
As you have already found out, it is not a Revit issue. It could be a file issue but more than likely it is a user issue. User error is the hardest to solve because of the variables.
Create a new view (not a copy - new from the view tab) and see what happens?
Audit your file....
Large Toposurface and File Size |
Fri, Aug 29, 2008 at 10:15:18 AM
split surface hides surface aligned component families |
Wed, Jul 31, 2019 at 7:37:57 AM
Topography on Revit 2009 |
Wed, Jul 2, 2008 at 10:38:54 AM
toposurface |
Tue, Dec 6, 2005 at 3:49:57 PM
Surface Troubles |
Tue, May 22, 2012 at 9:25:17 AM
