Forums >> Revit Building >> Technical Support >> Intersecting Walls - vertically stacked
Thu, Mar 14, 2013 at 2:04:30 AM | Intersecting Walls - vertically stacked
DoubleW
I’m working on a large shed with tilt-up concrete walls to a height of 3500mm and a framed wall above clad in corrugated steel, up to the roof.
I’ve made up the two different wall types, and have one sitting on the other (attached section shows makeup of the framed wall) however I’d like the external corrugated iron cladding of the lightweight part to overlap the concrete for waterproofing purposes.
How can I make them intersect so that the overlap remains?
I’ve tried the ‘cut geometry’ to trim out part of the upper wall but it cuts it right across.
Any suggestions on how to build this?
Thanks!
Learn Things Blisteringly Fast (Don't be Fooled by the Title):
http://www.amazon.com/dp/030746363X/?tag=wbww-20
Thu, Mar 14, 2013 at 4:57:46 AM | Intersecting Walls - vertically stacked
4 Stars: 205 Votes
This is the way on how you have to approach that: http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/0328-Build_th328/0330-Architec330/0331-Walls331/0336-Modifyin336/0347-Working_347/0350-Modify_T350
Wed, Mar 20, 2013 at 3:03:01 AM | Intersecting Walls - vertically stacked
DoubleW
Thanks Typhoon!
That was so simple!
vertically stacked walls
Wed, Jan 26, 2005 at 8:48:43 PM
intersecting inner walls with slanting outer walls
Wed, Feb 27, 2013 at 7:51:10 AM
stacked walls
Mon, Sep 10, 2018 at 9:55:14 AM
stacked walls
Tue, Nov 25, 2014 at 5:51:10 PM
stacked walls not editable
Sat, Aug 17, 2013 at 1:27:27 PM
Page generation time: 1.1755
