Forums >> Revit Systems >> Tips & Tricks >> Is there a way to control underlay view?
Tue, Mar 12, 2013 at 3:05:38 PM | Is there a way to control underlay view?
BlueFairy
I only want to show the walls of the of the level that is underlayed. However everything including the doors and components are showing right now. How do I get around this?
Tue, Mar 12, 2013 at 5:28:00 PM | Is there a way to control underlay view?
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
An underlay is not a plan view and it abides by no view range altough it can be affected by the local view range if the local view range overlaps the underlay's level.
An underlay is a 3d slice from the level of the plan view you are underlaying up to the next level. By default it should not show door swings and panels or windows because in plan view those default REVIT families use detail lines to be represented and underlays don't show 'detail lines'. If you have custom doors and windows that situation could be different.
In wireframe it will show the door and window openings.
Your solution may be to just hide those elements in the view and be done with it.
Underlay line weights
Fri, Oct 12, 2007 at 7:19:56 AM
Underlay is not working
Mon, Apr 28, 2014 at 5:29:50 PM
3d view not on screen, like zoomed out 1000x
Sat, Oct 3, 2009 at 10:22:47 AM
View Underlay on creation problem and solution
Sun, May 12, 2013 at 8:02:50 PM
Where is my underlay?
Fri, Mar 20, 2009 at 11:43:15 AM
Page generation time: 2.1953
