Forums >> General Discussion >> Revit Project Management >> REVIT MEP typ File size limit
Tue, Mar 12, 2013 at 10:35:53 AM | REVIT MEP typ File size limit
Nashid360
I have just recived a large 620MB revit file.  This MEP file seems very large and hard to work with.  what is the typical file size limit for MEP projects?
Tue, Mar 12, 2013 at 10:39:20 AM | REVIT MEP typ File size limit
Was this just MEP or MEP with arch & struct bound into it and no linked files?
Tue, Mar 12, 2013 at 10:46:39 AM | REVIT MEP typ File size limit
Nashid360
this is only the MEP
Tue, Mar 12, 2013 at 11:15:13 AM | REVIT MEP typ File size limit
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
How big is the project?  That seems very big. Are their a bunch of imported/linked elements from CAD or Revit?
Tue, Mar 12, 2013 at 11:18:37 AM | REVIT MEP typ File size limit
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
620MB is MASSIVE. Is this all the MEP for an entire airport or perhaps a 1000 unit condo building or something. What is the project of ? Haven't come accross a model that big in all my travels.
Tue, Mar 12, 2013 at 12:52:31 PM | REVIT MEP typ File size limit
Nashid360
it is a public safety building, not that big only 2 floors.  it looks like the problem is there are corrupted items within the MEP file.  a error mesage says items are corrupted" is now showing
Tue, Mar 12, 2013 at 1:59:43 PM | REVIT MEP typ File size limit
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Ok well that's kind of heed news. There's no way a building that size should produce a file that size. See if you can get the Element ID if the problematic objects. REVIT will let you locate objects by Element ID. Then delete / replace / fix them.
Tue, Mar 12, 2013 at 2:02:38 PM | REVIT MEP typ File size limit
Nashid360
ok thanks
Tue, Mar 12, 2013 at 2:21:48 PM | REVIT MEP typ File size limit
This may be a Revit file but with a 3D CAD import.
render size limit
Fri, Jun 20, 2008 at 7:11:10 AM
File Size
Wed, Jan 23, 2008 at 8:48:19 AM
Linking Revit MEP, Structural Models into Revit Architecture
Mon, Apr 23, 2012 at 4:00:03 PM
REVIT MEP - Separate models for MEP disciplines
Tue, Jun 25, 2013 at 1:45:42 PM
CAD Import - File Exceeding Size
Fri, Jul 10, 2015 at 9:16:32 AM
Page generation time: 4.3394
