Forums >> Revit Building >> Technical Support >> How to make Families have Solid Material? .stl export trouble
Sun, Mar 10, 2013 at 10:44:49 PM | How to make Families have Solid Material? .stl export trouble
Cmiracle
Cmiracle Avatar
Hello, I'm using Revit 2013.
When trying to export families that I have downloaded as .stl files, I get the error message-
"Family does not contain solid material. Unable to Save."
How do I add materail, or make the program reconize that those downloads are made of something? I have had no trouble exporting stock Revit Library objects, but would like to also print and use the downloads in my model
Mon, Mar 11, 2013 at 5:46:23 PM | How to make Families have Solid Material? .stl export trouble
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
check out the threads at the bottom of this page they can probably help
Mon, Mar 11, 2013 at 6:34:04 PM | How to make Families have Solid Material? .stl export trouble
Cmiracle
Cmiracle Avatar
I wish they did, but they all have no replies or are about 3D printing, which we have done quite a bit. My problem is odd, as it will export some of my downloaded families but not all. I believe it is how the families were made, but I don't know how to fix them.
Edited on: Mon, Mar 11, 2013 at 6:35:40 PM
Tue, Mar 12, 2013 at 7:05:51 AM | How to make Families have Solid Material? .stl export trouble
Perhaps it would be better if you explained more.  Like what families don't export?  Maybe posting one of them.
Tue, Mar 12, 2013 at 9:22:21 AM | How to make Families have Solid Material? .stl export trouble
Cmiracle
Cmiracle Avatar
Okay, this tub is a good example. It will export, but when the file is viewed, only the rod and curtain were actually exported. You can delete the rod and curtain and try again, but then the "this document has no solid" error message appears. Something is different on the curtain/rod than the rest of the tub?
Edited on: Tue, Mar 12, 2013 at 9:23:32 AM
Edited on: Tue, Mar 12, 2013 at 9:30:55 AM
Tue, Mar 12, 2013 at 9:44:25 AM | How to make Families have Solid Material? .stl export trouble
The tub is a CAD import.  It is only solid planes - not solids.
Edited on: Tue, Mar 12, 2013 at 9:46:55 AM
Tue, Mar 12, 2013 at 9:52:34 AM | How to make Families have Solid Material? .stl export trouble
Cmiracle
Cmiracle Avatar
Ah. Is there a way to extrude all the planes a little to create a solid surface?
Exporting Topo to STL as a solid for 3D Printing
Fri, Feb 9, 2018 at 4:51:21 AM
hoe do you export an STL file for 3d printer
Mon, Jan 5, 2009 at 5:10:05 PM
.stl file creation?
Thu, May 17, 2007 at 12:50:53 PM
How do you export to STL with materials
Tue, Oct 4, 2011 at 9:54:31 AM
Fireplace doesn't export out into STL file
Sat, Jan 24, 2015 at 9:24:41 AM
Page generation time: 3.3517
