Forums >> Revit Building >> Technical Support >> I need help for Mass from other Application
Sun, Mar 10, 2013 at 9:12:19 AM | I need help for Mass from other Application
akarawat6363
akarawat6363 Avatar
4 Stars: 4 Votes
Hello, I have project that come form sketchup file, and I never use Mass in real project before,
Can somebody help me to describe a step to do when Sketchup file is imported. how to complete
mass with imported file. for mass wall & mass floor. Thank you Smile
Wed, Mar 20, 2013 at 5:26:41 PM | I need help for Mass from other Application
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
If I recall correctly you make an in-place mass family and insert the SKP file into it. Then use the model by face tools.
Thu, Mar 21, 2013 at 4:26:23 PM | I need help for Mass from other Application
hydyr96
4.5 Stars: 8 Votes
Honestly it depends on your needs, if the mass is too big, then most probably you'll have to do again revit, if not, as one of the friends said, use "by face tools". Search on: walls by face in revit, the same method is applied for roofs and floor... (if you do it from mass)
Fri, Jun 21, 2013 at 7:32:51 AM | I need help for Mass from other Application
akarawat6363
akarawat6363 Avatar
4 Stars: 4 Votes
Thank, dgcad & hydyr96
Curtain System from Mass - Mullion Joins
Fri, Dec 11, 2015 at 7:27:44 PM
Cutting a section through a mass
Sat, May 16, 2020 at 4:21:54 AM
Why doesn't reivt have the simple autocad commands that we know and love.
Mon, Mar 30, 2009 at 9:22:21 AM
Help wth Mass Please !
Wed, Nov 25, 2009 at 2:53:24 PM
Revit Application Engineer
Thu, Apr 10, 2008 at 5:49:53 PM
Page generation time: 1.5995
