10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> HIDING SEVERAL INSTANCES OF THE SAME ITEM IN A SCHEDULE
11 Posts No Rating |
Hi all,
I've just made a Note Block to schedule a bunch of symbols. Here's my problem. I've got different data comming from the same symbol family so in the schedule I'm getting several instances of the same information. I would like only one instance of each symbol 'info set' to be shown in the schedule
If I uncheck the 'itemize every instance' check box then it only shows me one item as the symols are from the same family.
Is there any way around this? I'm thinking I might have to add an instance parameter to the symbol family and number them differently.
I'd have to get more detail but my first thought would be to setup a 'filter' in the schedule.
We add a do not schedule, project parameter to almost all categories in our projects. Then we filter out those elements with an X in this parameter.... Useful in many categories including sheets.
Great answer and valuable tip. YOU'RE HIRED !
Sorry guys that it's taken a while to get back to you. Thanks for all of your help and WWHub I used your sugestion. It looks like the only way around it.
Thanks again.
Find objects in views using "Select All Instances in View" |
Tue, Sep 3, 2024 at 5:10:21 AM
Graphical Column Schedule - Not Grouping all similar instances |
Wed, Nov 5, 2008 at 11:11:18 AM
Hiding Certain Doors from a Door Schedule |
Tue, Jun 26, 2012 at 7:10:19 AM
Hiding a Revision in the Revision Schedule |
Thu, Nov 21, 2013 at 3:04:51 PM
multiple instances of the same view in sheet not supported |
Tue, Dec 4, 2012 at 12:40:35 PM
