Forums >> Revit Building >> Technical Support >> Stairs: Hide Tread and Riser in Section View
Fri, Mar 8, 2013 at 10:27:41 PM | Stairs: Hide Tread and Riser in Section View
Luquex
I need to "Turn off" the Tread and Riser on a monolitic stair, in section,
To solve the problem I´ve done a Mask locked to the botom of the Tread and Riser.
I wonder if there is a better way to solve it, like "turn off tread and risers" from Visual Graphics, but´s not possible
Thanks.
Mon, Mar 11, 2013 at 7:42:08 AM | Stairs: Hide Tread and Riser in Section View
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Why not just click on the stair and Hide in View?
Mon, Mar 11, 2013 at 8:36:41 AM | Stairs: Hide Tread and Riser in Section View
Luquex
This Work will have two phases,
First Phase, only to make the Monolitic Stair.
Seconde Phase, to make the finishing (Threads and Risers, Railing, etc)
So we need to see the Monolitic part, and anotate levels on them.
Thanks
How to model a non-typical length stair tread for the top tread
Mon, Jan 25, 2016 at 1:55:19 PM
Cleaning up a Stair Tread & Floor Connection
Thu, Nov 3, 2016 at 8:45:39 AM
How do you alter stairs in revit so that they could have a tread of 9" and riser
Fri, Sep 28, 2012 at 1:27:53 PM
Stair Riser/Tread Number in Multistory Stairs
Tue, Sep 13, 2016 at 9:47:54 AM
PRECAST STAIR BEGIN WITH RISER LOOKS INCORRECT ON PLAN
Fri, Sep 2, 2016 at 7:03:03 AM
Page generation time: 2.6887
