Forums >> Revit Building >> Technical Support >> Case opening does not have casing.
Fri, Mar 8, 2013 at 8:41:44 PM | Case opening does not have casing.
BlueFairy
I see that my cased openings in 3d views are cased but I dont see them in section views.  I checked to see that the trim width is at 3.5 under type Properties and the diminesions are set as I want them but I just  dont see them on my section views... Confused.. another glitch in revit?
Mon, Mar 11, 2013 at 7:41:02 AM | Case opening does not have casing.
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Most likely not a Revit problem but a family creating problem or user error.  Does the trim show up in the family?  Is it checked to show in all views and detail levels in the Family Element Visibility Settings?
Cased openings not displaying casing.
Thu, Jun 18, 2009 at 10:55:21 AM
radiused corners at door and window openings?
Mon, Oct 25, 2010 at 6:08:57 PM
Trying to calculate casing take off for interior doors
Mon, Jan 14, 2013 at 8:48:35 AM
Casing profile won't apply to model - Revit 2011
Thu, Aug 11, 2011 at 12:37:14 PM
Advice on beam casing
Fri, Oct 14, 2011 at 11:19:49 AM
Page generation time: 2.2233
