Forums >> Revit Building >> Technical Support >> Wall Sweep
Fri, Mar 8, 2013 at 2:59:40 PM | Wall Sweep
frankmm
Hello,
I am using REVIT Architecture 2013. I am trying to place a wall sweep on a wall that has a slope. The wall sweep does not adhere to the slope. Is there a way I can make the wall sweep slope with the wall?
Thank you in advance,
Margaret
Sat, Mar 9, 2013 at 4:43:28 AM | Wall Sweep
4 Stars: 205 Votes
You have to create that with "IN-PLACE" then use the sweep tool.
Mon, Mar 11, 2013 at 7:48:37 AM | Wall Sweep
frankmm
I was able to add the coping through "IN-PLACE" as suggested, but now it appears that there are lines extending upwards from four corners. How do I remove those lines?
Mon, Mar 11, 2013 at 9:16:43 PM | frankmm
vicozzio
Quoting frankmm from 2013-03-11 07:48:37
If you create it with In-Place model, to clean up the model.. I believe you have to do it in the In-Place as well.. you have to cut it using void to get clean joint..
Wall sweep won't trim
Tue, Apr 25, 2017 at 2:07:17 PM
Repeatig wall sweep vs. repeating detail - wall attached [ 1 2 ]
Sun, Dec 7, 2008 at 3:51:44 PM
19
How to Load a Wall sweep type
Mon, Jun 9, 2008 at 12:42:29 PM
Hosted Wall sweep
Thu, Jul 28, 2005 at 10:10:34 PM
Wall Sweep..... or something else... any suggestions??
Tue, Jul 15, 2008 at 10:07:17 AM
Page generation time: 4.0341
