Forums >> Revit Structure >> Technical Support >> new to existing slab joints
Fri, Mar 8, 2013 at 2:12:54 PM | new to existing slab joints
AKDV
When placing a new slab on grade adjacent to existing slab the joint appears in halftone.  I do want the existing phase in halftone, but I want the joint to show dark (new joint).  Any ideas?
Mon, Mar 11, 2013 at 7:24:34 AM | new to existing slab joints
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
In plan view or section?  Your "joint" thats just a space between your new and existing right, you didn't use a detail component or anything to make the joint?  If its just  a space you will have to use the linework tool and change the ende of the existing slab to a darker color.  If this doesn't answer your question add some images for further clarify your problem.
Sun, Mar 24, 2013 at 5:57:18 PM | new to existing slab joints
AKDV
The joint is at the interface between a new and existing foundation slab (model element).  It is a "cold" joint so there is no space between the new and existing elements.  I guess I want the darker lines to print over the top of the gray shade if possible.  I think it was possible in AutoCAD.  I have attached pdf views.
Thanks,
Mon, Mar 25, 2013 at 7:53:36 AM | new to existing slab joints
Teafoe gave you your answer.
Tue, Mar 26, 2013 at 6:29:35 PM | new to existing slab joints
AKDV
OK, thanks.  Was hoping there was a global setting for new/ex phases.
Tue, Mar 26, 2013 at 9:33:42 PM | new to existing slab joints
RevitBJO
I might be missing something here. Did you take that sectional image from the 'snipping tool' or is that a PDF of an actual print ?
It may look wrong on screen, though the darker line will prevail when printed...I would have thought.
Cheers,
Control Joints in a concrete slab
Mon, Jan 18, 2010 at 2:21:39 PM
new slabs, existing slabs, and the nature of constraint(s)
Wed, Dec 11, 2013 at 12:21:24 PM
vertical joints in hosted wall sweep?
Mon, Aug 13, 2007 at 3:37:15 PM
Slab at header block, curious on methods....
Tue, Nov 11, 2014 at 9:38:05 AM
existing floor system
Tue, Mar 6, 2012 at 10:02:21 AM
Page generation time: 0.5430
