Forums >> General Discussion >> Revit Project Management >> Recently placed in charge of Revit group at firm
Wed, Mar 6, 2013 at 10:24:50 PM | Recently placed in charge of Revit group at firm
tolosegt
Hey guys, I wanted to get some pointers on how to lead a small group of architects and engineers for a huge project.
My firm wants to switch to BIM by the end of this year, and this project is sort of a test on the capabilities of Revit. Since I am one of the few people at this hundred person firm that knows Revit (Chinese firm), I was placed in charge of an interdisciplinary team to integrate an ongoing project into BIM software, namely Revit.
Some big things to know is that this project is in the DD phase and everyone is using a Chinese AutoCAD mod called TArch. The people on this team have just started dabbling in Revit, so this will be a primarily learning exercise, although the project manager has stated that we should expect to turn in some construction documents near the end.
I'm familiar with some of the collaboration options in Revit, like linking files, separate Architecture/Structures/Systems files, but I'm not as clear on worksets and how to go about implementing those. I've read FAQs and guides on them, but if any of you guys have any experience on collaborating between the Revit disciplines and working on multiple files, that would be extremely helpful.
Thu, Mar 7, 2013 at 7:47:20 AM | Recently placed in charge of Revit group at firm
I don't think you want to jump into a project mid-stream with Revit.  There is just too much to learn and everyone will be frustrated and disappointed.  You are far better off to be using Revit early in a small project to build your knowledge.  Deadlines can kill your learning process.
That being said, worksets allow multiple users.  My initial advice is don't go overboard with the number of worksets you use. I suggest for architecture:
  • Levels and grids
  • Workset one
  • a workset for every linked file
  • Shell ( All exterior components of the model)
  • Interiors (furnishings)
  • maybe owner provided
On very large projects, you may add additional worksets per level or area so that you can use reduced loadings to improve performance but you should not be in a model like that yet.
The shell workset allows you to have exterior views / 3d etc where you only need the exterior and you will improve model performance.
Understand that linked files are never re-linked.  Just use the reload from in the mange linked files area.
Thu, Mar 7, 2013 at 10:48:55 AM | Recently placed in charge of Revit group at firm
coreed
coreed Avatar
4 Stars: 16 Votes
I would tell your firm/bosses to invest in some implementation consultants to help you guys along. A hundred person firm is no small test. Even your pilot project sounds all wrong for a first project. Also the capabilites of Revit do not need to be tested. The program has been proven capable by the market place. What you will need is a capable implementation plan. I'm sure you will learn a lot in what you are attempting to do with this project, but it also sounds like there will also be a lot pain and aggrevation also. Best of Luck.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Fri, Mar 8, 2013 at 12:43:39 AM | Recently placed in charge of Revit group at firm
tolosegt
Hey guys, thanks for you time.
Here is a reply I posted with further information on where I am coming from:
"Hey guys, I really appreciate the discussion about implementing Revit here. After further talks with my project manager, I have a much clearer idea of what they want with this particular project. Thankfully I have the backing of the senior staff and they recognize that switching from 2D AutoCAD to 3D BIM design will be a slow and often times painful process.
Here is some more information regarding this project. I am part of design team that specializes in hospital and healthcare architecture. We have collaborated with the firm's structural and MEP system engineers before, and we are in the middle of 3 projects, one of which is the one I talked about in my OP. One thing to note is that there is very little free time to work on a test model, as most of our time is taken up by on-going projects. However, the reason why I believe we can implement BIM successfully at this firm is because the project managers are assessing this transition period carefully and methodically.
We have hired a BIM consultant to work with our firm's small (3 person) BIM center on the projects they have going on, which mainly consists of tutoring them on family creations I think, while I will be leading the BIM team for this particular project. I will come out and say honestly that I have at least a year or two on the people in the BIM center, which was one of the reasons I was hired and placed on this design team. While our BIM center will concentrate on creating families, I will be overseeing the creation of the project's Revit model and working on our firm's BEP with our BIM consultant. While this project won't be completely using BIM, our next one will most likely be, so I really want to gather as much information and ideas from you guys as you're willing to give in order to minimize the aches and pains we'll no doubt go through.
To answer a question: I am leading an interdisciplinary team that will focus directly on Revit modeling. There will be a few architects and engineers; one for each M E P, one for structural, one for landscaping, one for interior design, and me for architecture. Our Revit experience is all over the map, but we are relatively young and have been exposed to BIM and its concepts."
WWHub: What are the benefits of creating a workset for every linked file? I was under the impression that linked files cannot be edited unless you open the linked filed, which unloads it from the parent file. Would this be enough of a buffer to stop other disciplines from editing the file?
Also, thank you for the tip on shell worksets. That could come in handy when our clients want to see some progress work.
As for worksets for grids. I just pin my grids. Is that enough?
Edited on: Fri, Mar 8, 2013 at 12:45:04 AM
Fri, Mar 8, 2013 at 8:25:55 AM | Recently placed in charge of Revit group at firm
The purpose of separate worksets for linked models is simply control and better performance.  This has nothing to do with controlling editing.  In many views, you don't need all the links.  By creating a workset that is set up to be not visible in all views you can turn that workset on only where you need it.  This is especially true for 2D cad links.  Also, you can use reduced loads at opening on very large files.  BTW - You typically want very few CAD links (None if possible) so at most you might have 4-5 Revit links.
Levels and Grids is a standard workset and most firms leave that alone as is.  As far as pinning, I personally don't recommend pinning all grids.  I recommend that you pin your first grid in both directions the dimension lock from there the remaining grids.
Hourly Charge
Thu, Jan 24, 2008 at 9:07:40 PM
How much to charge for plan and elevations?
Mon, Aug 6, 2012 at 5:59:46 PM
How much should I charge?
Fri, Apr 18, 2008 at 4:17:53 PM
Revit user group
Wed, Feb 6, 2008 at 12:58:12 PM
Revit Newbie
Mon, Jul 30, 2007 at 9:56:36 AM
Page generation time: 3.5304
