18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> 3D DWG as RFA too big
Hello,
I imported a 3d dwg of a wash basin to convert it to rfa but it ends up with 23Mb. this is way too big.
I have several dwg I need to convert to rfa.
Is there a better way to trim down the file size?
many thanks
Revit Architecture 2013
ArchiCAD 16 Win
Windows 7 Enterprise 64-bit |
You did a 3D import correct? Not exploded so really not converted.
I imported the CAD file. When I try to explode the imported, everything disapears.
ArchiCAD 16 Win
Wait!
Fixed it. Was importing with the wrong units (meters instead of milimeters).
ArchiCAD 16 Win
Ambrozote... One BIG RULE... before importing your CAD file into Revit, open that in CAD, explode everything, delete hatches, dimensions, texts and PURGE the file.
You are right Typhoon.
I remembered all that. But in this case there was a single 3D Solid entity.
If you are curious, see attached file.
ArchiCAD 16 Win
you could use this external command for 3D DWG http://puntorevit.blogspot.it/2014/01/3d-dwg-to-rfa-external-command.html
Dwg to RFA and Materials. |
Sun, Feb 2, 2014 at 1:40:54 PM
DWG 3D TO RFA CONVERSION? |
Sun, Feb 2, 2014 at 1:37:21 PM
Multiple import dwg as multiple Family |
Sun, Apr 9, 2017 at 8:38:41 AM
From .Dwg to .Rfa |
Tue, Feb 24, 2009 at 1:32:24 PM
Are there any dwg /dxf files to download, all I see is *.rfa |
Thu, Feb 5, 2009 at 10:12:18 AM
