Forums >> Revit Building >> Technical Support >> Rope Column
Fri, Jan 27, 2006 at 4:03:32 PM | Rope Column
IRVING
I have hours into getting nowhere. I have been trying to extrude a circle around an "s" in the front then rotating it in a plan view. It don't seem to work. anyone got any better idias? Thanks another couple of hours trying blends and void revolutions not so sure thats any better but its gonna be a long weekend Post edited on 2006-01-27 17:44:17
Fri, Jan 27, 2006 at 4:19:34 PM | RE: Rope Column
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
So you want to sweep a circle along in an S shape? I don't understand the rotating part? Rotating a circle doesn't change anything? Simply set a workplane for the sweep, draw your path in elevation then draw the profile of the circle at the appropriate radius.
Fri, Jan 27, 2006 at 6:03:15 PM | RE: Rope Column
IRVING
after sweeping the circle along the s in front view I rotated/copied the sweep 3 times in plan view to create 3 pieces of rope that I thought I could join into a column which mght work if I could figure the right relationship of the radius of the circle to the radius of the s. 1/3 seems obvius but aint it. After lokking at your example it seems I shold be able to revolve groove out of a round column and get the right look maybe an array in a circle of slanted void revolves slicing a round column. I need a break
Sun, Jan 29, 2006 at 1:23:29 AM | RE: Rope Column
hippy
so I build a rope column in autocad by splining a 3dpoly then using short segments to create the path but when I try to import it I am asked for a 3dmesh??? How little do I know? Any hints?
Mon, Jan 30, 2006 at 12:11:55 PM | RE: Rope Column
hippy
2d sketch
Mon, Jan 30, 2006 at 12:32:02 PM | RE: Rope Column
hippy
renderable 2d this is a void revlve that only works if the front is perpendicular to the camera if you could put tis together with my 2d sketch with rotated copies and complex visability controles you could have a rope column fake-out maybe someone could do a better one as a balister.
Mon, Jan 30, 2006 at 1:44:00 PM | RE: Rope Column
reviteer
1 Stars: 1 Votes
I have an operational rope column that you guys could swipe and modify as you see fit. let me know if you want it. Hey Irving, where at in Naples?! I am in paradise too... If you guys want the column, just yell and i will upload it. We tackled this issue by using symbolic lines to represent the rope. We did a twisted column (cant remember the fancy name for it) as well, this one we did by revolving a circle through 180, and the angling it upward. mirror and copy up and join it all...
Sun, Feb 5, 2006 at 11:38:31 AM | RE: Rope Column
hippy
Reviteer, We would very much be interested in your rope column, and probably several other solutions that you have had to work out that are Southwest Florida specific. I will update my profile. Please get in touch. Thank You, Irving R Layne Jr
Sun, Feb 5, 2006 at 5:19:45 PM | RE: Rope Column
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
http://forums.augi.com/showthread.php?t=23158&highlight=rope+column
Mon, Feb 6, 2006 at 12:25:18 AM | RE: Rope Column
hippy
talk about doing things backwards. I am revlolving voids and Peter J pulls it off by revolving a solid. I still lose I sketched this one into my drawing and the boss said it was ugly. Yet it looks amazingly close to what Peter J maid and what I spent hours trying to make. I am still going to have to have soething like this. They are very common around here. Guess I will steal a sketch off an old drawing before I start trying to model again
Rope Lights Revit MEP 2012
Tue, Nov 29, 2011 at 12:10:11 PM
how to make a recess celling for rope light
Thu, Jun 16, 2011 at 2:21:34 AM
DISPLAY COLUMN LABELS
Wed, Sep 8, 2010 at 3:53:41 AM
Column Capitals
Wed, Sep 18, 2019 at 8:39:07 AM
L shaped column
Mon, Jun 22, 2015 at 4:37:29 AM
Page generation time: 1.4417
