28 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Lower casework showing through when touching counter?
Hello there,
I'm racking my brain trying to figure this out. I have a counter top at 2'-10" (ADA Heights), and I have casework below at 2'-8 1/2" and the counter thickness is 1 1/2".
In Plan view my casework is showing through the counter, so naturally I went to see if a masking region was in the counter family. Sure enough it's there. But then if I set my casework height to 2'-8" (any height NOT TOUCHING underside of counter) then the masking region does it's job and doesn't show the casework below.
How do I get this to show NO CASEWORK if it's below my counter, even when it's touching the underside of it?
Thanks,
Lorne
Denver, CO
Revit Architecture |
The masking region is at the wrong place in the family. I prefer to use solid objects for counters and table tops just because of this problem.
Thanks for the reply WWHub,
I didn't know masking regions can be assigned a work/reference plane? Thought they were annotations that are view driven. The family we have for some reason has the counter turned off in plan. I forget why exactly, but there was a reason for it at some point. I agree though, I'd rather go the simplier route with less objects and just have the 3D geometry visible.
Thanks for the help.
Lorne
Denver, CO
Casework below countertop not visible. |
Wed, Jan 27, 2010 at 2:16:58 PM
shower enclosure & casework visiblity |
Sun, Nov 5, 2006 at 12:53:09 PM
Office furniture not showing through counter |
Mon, Sep 30, 2013 at 6:12:15 AM
Casework not loading into project |
Thu, Aug 15, 2013 at 7:36:39 AM
Phantom Casework |
Tue, Aug 28, 2012 at 12:25:48 PM
