Forums >> Revit Building >> Technical Support >> No components show up in floor plan
Tue, Mar 5, 2013 at 2:28:07 PM | No components show up in floor plan
homer382
I am using Revit Architecture 2012.  I was using a trial version on an office computer while waiting for my new computer.  I got my new computer today, and had the full version installed.  On one of my projects, components that had been placed before the new version are still visible.  However, if I try to add a new component (and I mean ANY component), it gives a warning (no loss defined), and does not show up.  It will show up in elevations, but wont show up on my floor plan.  Even if I click on an existing, visible component and use "created similar", it still will not show up, even though the original is visible.  I've tried view range, gone through my view graphics, everything.  Any suggestions?  Thanks.
Thu, Mar 7, 2013 at 4:40:58 PM | No components show up in floor plan
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
"No Loss defined" . . . . Is that the error ? Never seen that before.
What type of components furniture, speciality Equipment, Plumbing, Walls ?
Upload a screen capture(s).
Phasing ?
Design Options ?
View Discipline ?
View Detail Level ?
Visibility Graphics ?
Fri, Mar 8, 2013 at 6:58:36 AM | No components show up in floor plan
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Found in another post
"The two most common causes for the "No Loss Defined" warnings are fittings in certain conditions do not have loss information either from a table, or specified, and in the other case, there is no flow so there is no loss.The only change that was made for 2012 was that the warning was included under the displayable warnings. I would look at your fittings and make sure there is a loss associated."
Fri, Mar 8, 2013 at 9:46:23 AM | No components show up in floor plan
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
A bizarre answer to a bizarre question. a) What part of REVIT architecture uses fittings ? b) what's this got to do with not seeing components when you draw them in a floor plan where other items are showing ?
Fri, Mar 8, 2013 at 10:17:03 AM | No components show up in floor plan
DG,
I seem to remember having this happen awhile back with a toilet family. I don't remember what I did to get past the problem but I don't have the problem anymore.  That leads me to believe it was fixed in an update.
homer .... have you verified that you have the latest updates installed?
Fri, Mar 8, 2013 at 10:23:27 AM | No components show up in floor plan
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Now that would make sense.
Fri, Mar 8, 2013 at 10:24:00 AM | No components show up in floor plan
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I was simply responding the the "no loss defined" error.  Obviously there is some type of fitting or a family with a fitting in the project that is giving this error.  I don't have an answer for components not showing up.
Fri, Mar 8, 2013 at 10:30:19 AM | No components show up in floor plan
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Fair enough, not knocking your reply. You did manage to track down the actual error. I'd go with the software update. Toilets, sinks and yrnals have connectors but not fixtures or fittings. Only MEP has those components.
Floor with Valleys and Ridges - Hosted Components Won't Slope
Thu, Oct 28, 2010 at 2:01:36 PM
Floor plan showing ceiling fixtures and wiring to switches
Wed, Feb 18, 2009 at 2:49:44 AM
3d components show contour lines in plan view.
Tue, Apr 7, 2009 at 10:00:37 AM
13
Framing Plan - Getting Walls Below Floor to Show Openings
Thu, Jan 6, 2011 at 10:11:23 AM
Family don't show up in floor plan once load into project
Wed, Oct 20, 2004 at 1:35:51 AM
Page generation time: 0.7751
