Forums >> Revit Structure >> Technical Support >> Searching for the instances of a family within a project
Tue, Mar 5, 2013 at 9:51:44 AM | Searching for the instances of a family within a project
thazell
I am currently troubleshooting some old files.  Is there any way to search for the occurrence of a family in a file.  I know how to select all instances of a family and see how many occur.  Is there a way to locate these instances?
Thank you in advance
Tue, Mar 5, 2013 at 10:02:54 AM | Searching for the instances of a family within a project
I do it from a 3D view.
Tue, Mar 5, 2013 at 10:08:30 AM | Searching for the instances of a family within a project
thazell
Thanks for the response, actually the families are detail families in the drafting views.
Tue, Mar 5, 2013 at 10:28:11 AM | Searching for the instances of a family within a project
I wish you had been clear initially.
No way that I know of to find these items short of opening each view.
But here is a "bubble sort" option...
  • Open a new copy of the program
  • Make sur you know how many instances you have
  • Delete 1/2 the views then see how many instances you still have ... hopefully all of them
  • If say 1 drops off, you can search for one in the original views you deleted by bringing them back and deleting 1/2 of those.
  • Delete 1/2 of remaining and look at how many
As you can see, this can be a fairly fast way of finding the instances.
Tue, Mar 5, 2013 at 10:33:10 AM | Searching for the instances of a family within a project
thazell
Thank you very much.  That is a creative way to find the instances.
Tue, Mar 5, 2013 at 10:34:37 AM | Searching for the instances of a family within a project
thazell
Can a Schedule be created listing the family and the views they are in?
Tue, Mar 5, 2013 at 10:52:38 AM | Searching for the instances of a family within a project
I checked for that first and did not see a way.
Tue, Mar 5, 2013 at 11:01:40 AM | Searching for the instances of a family within a project
thazell
Thank you for your help. Find location of instance should be on the Revit wish list. If anyone finds another way, I am all ears.
Thu, Mar 14, 2013 at 8:23:17 AM | My Solution
thazell
The solution I came up with is this:
1. Select all instances
2. On the manage tool bar "show ids of selection"
3. Copy and paste into notepad
4. Copy a single ID from notepad
5. On the manage tool bar "select by Id"
6. Show
That's a solution that helps me find the orphaned family instances that exist in my project.
Locate instances of family, also Hello!
Tue, May 19, 2015 at 12:34:54 PM
Edit Parameters of Nested Family from Project
Tue, Feb 2, 2016 at 8:54:40 AM
Select All Instances does not actually show all instances
Thu, Mar 28, 2013 at 1:38:37 PM
Find objects in views using "Select All Instances in View"
Tue, Sep 3, 2024 at 5:10:21 AM
File size and performance with multiple instances of 3d families
Wed, May 26, 2010 at 4:10:42 PM
Page generation time: 3.2842
