Forums >> Community >> Newbies >> Custom Keynotes
Tue, Mar 5, 2013 at 8:15:16 AM | Custom Keynotes
davidjohansson
Can someone please help me find a site or something that explains how you create your own custom keynotes? Where they explain how you should write what in the Keynote text document etc.
Thanks!
D
Tue, Mar 5, 2013 at 8:36:19 AM | Custom Keynotes
There are several pages of information in your HELP .... that is your best resource.  From your HELP:
Keynotes are defined in a tab-delimited text file. The first portion of the text file is reserved for major headings/categories (the parent values). The remainder of the file is for sub-headings/categories (the child values). A tab-delimited file requires the use of the Tab key to create spaces between data entries.
Changes made to the keynote table are not available in the current project session of Revit. Changes are available when the project is closed and reopened.
You can use Microsoft® Excel or a similar spreadsheet application to manage the data, then export it to a tab-delimited file format.
There are two sample files that you can start with:
Keynote File Versions
Table of contents No headers
The following files are provided and installed during deployment:
  • RevitKeynotes_Imperial.txt
  • RevitKeynotes_Metric.txt
Tue, Mar 5, 2013 at 8:40:54 AM | Custom Keynotes
davidjohansson
Great! Thank you.
Keynotes
Thu, Mar 15, 2018 at 3:15:03 PM
Keynotes
Thu, Oct 6, 2005 at 5:13:33 PM
KEYNOTES: only one keynote txt file and legend?
Wed, Jan 17, 2018 at 12:33:01 PM
some keynotes not printing
Thu, Sep 15, 2016 at 4:43:39 PM
Keynotes - Ledgend management
Mon, May 11, 2009 at 7:01:29 AM
Page generation time: 5.5714
