10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Associated level not correct
87 Posts No Rating |
I have a second floor plan that has its properties associated with the roof plan as indicated in the Properties bar. Consequently every component I place in the plan such as a chair is placed ant the roof level. I dont know how to change the associated level to be second floor since the menu is greyed out. I dont know how this happened. There must be a way to correct this.
Thanx for anyone who can answer any of my complicated questions. ah!
Hi BlueFairy,
You might accidentally renamed the name of that level but didn't check "Yes" for pop-up window "Would you like to rename cooresponding level and view".
Go to plan view, select the level you have problem in the "Project Browser", right click, you will see a "pop up" window with "Rename" option; select and rename that level and check "Yes" when "Would you like to rename cooresponding level and view" showed. Hope that can fix your problem.
Well, ...I had to delete the floor plan in the project browser. I went under the views tab and found the "Plan Views" and selected the floor plan option. I found the 2nd Floor which had the association problem. I highlighted it and clicked the OK button.. Now it has the correct association. Cross my fingers and hope nothing bad happened.
Thanx for all your help.
How i can change the level with out move the building |
Sat, Apr 29, 2017 at 8:03:05 AM
Revit 2011 - Curtain Wall doors on Schedule for correct level |
Thu, Jun 7, 2012 at 1:22:49 AM
floor plan is not shown correct.. some parts are shown as below level |
Wed, Nov 10, 2010 at 3:18:15 PM
topography not being generated at the correct level |
Thu, Oct 12, 2017 at 8:01:15 AM
Problem with level display |
Tue, Apr 6, 2010 at 12:58:24 PM
