Forums >> Revit Building >> Technical Support >> Roof Extrusion Trouble
Mon, Mar 4, 2013 at 11:50:53 AM | Roof Extrusion Trouble
Cmiracle
Cmiracle Avatar
Hello, I am using Revit 2013.
I have created this roof shape by extruding a profile from a workplane, but I can't figure out how to control how it connects to the rest of the roof. It continues on into this room, instead of stopping at the joint of the two roofs. How would I be able to stop the extrusion at the roof joint?
Mon, Mar 4, 2013 at 12:00:29 PM | Roof Extrusion Trouble
If the ridge of that roof is flat, it can be made with the remainder of the roof and that is your better solution.
Tue, Mar 5, 2013 at 11:59:27 AM | Roof Extrusion Trouble
Cmiracle
Cmiracle Avatar
Thank you for your promt reply! Despite working with it myself and trying to understand what you said, I am still at a loss as to how to make that roof shape. Would you mind elaborating, please?
Tue, Mar 5, 2013 at 12:13:26 PM | Roof Extrusion Trouble
I cheat a little but it can be so small it doesn't show.  See views.
Tue, Mar 5, 2013 at 12:29:40 PM | Roof Extrusion Trouble
Cmiracle
Cmiracle Avatar
Wow, thats a great solution, Thanks!
Tue, Mar 5, 2013 at 12:39:04 PM | Roof Extrusion Trouble
4 Stars: 205 Votes
No need to cheat, break the line then use the "Slope arrow"
Tue, Mar 5, 2013 at 12:43:01 PM | Roof Extrusion Trouble
Your right Ty,  I hade forgotten that.  I broke the line initially and could not get it to work.  I forgot the arrow.
Barrel tile roof by extrusion
Fri, Jan 14, 2011 at 1:10:17 PM
Revit 2012 Roof by extrusion
Sat, Nov 19, 2011 at 4:49:20 AM
Joining Roof By Extrusion
Mon, Jan 31, 2011 at 8:15:14 AM
Roof Join / Entension Trouble
Thu, Feb 11, 2016 at 9:52:09 AM
curved roof
Wed, Jul 4, 2007 at 7:29:47 AM
Page generation time: 0.3323
