Forums >> Revit Building >> Technical Support >> Manually applied custom panel being flattened
Mon, Mar 4, 2013 at 7:15:25 AM | Manually applied custom panel being flattened
robest
Hi there,
I've got a conceptual mass with a curved profile face that I've divided with a basic vertical grid (no horz). I've build a custom pattern-based curtain panel family that is simply a pane of glass and a triangular roof strut leaning away from it. I can apply this fine to the face, but the final panel doesn't work, it insists on adding a subdivision (I assume because of the inclinded edge. So I deleted the final panel and then manually placed an instance of the same panel family, clicking on the four vertices of the pattern. This almost works except that the triangular strut is flattened down on to the glass.
Any thoughts?? (I'm using Revit 2013)
Cheers
Rob
Thu, Mar 14, 2013 at 10:01:09 AM | Manually applied custom panel being flattened
robest
Ok, so if anyone is interested it seems that the behaviour I was getting (the panel being flattened on to the wall) was because when I was applying the panel manually I had 'Place on Face' selected rather than 'Place on Work Plane'. Using the latter fixed it and the panel placed correctly.
Another tip, when placing edge panels manually, use the 'Surface Representation' toolbar to turn off surface and component views leaving just the Pattern view. This will allow you to more easily snap the new panel to the correct nodes without the geometry of the rest of the panels getting in the way.
Cheers
Rob
Custom Precast Wall Panel
Wed, May 20, 2015 at 3:10:54 PM
Slope Roof with custom curtain panel
Fri, Dec 4, 2009 at 12:35:08 AM
Custom panel family within a curtain system
Tue, Nov 3, 2009 at 11:59:10 AM
custom shape of curtain panel results in panel replacing
Mon, Apr 12, 2010 at 12:17:28 PM
Custom Panel Schedules in REVIT MEP
Mon, Jul 23, 2012 at 12:19:22 PM
Page generation time: 0.2853
