Forums >> Revit Building >> Technical Support >> How to create wall for angeled staircase -
Mon, Mar 4, 2013 at 1:01:52 AM | How to create wall for angeled staircase - Revit 2012
tectacoma
tectacoma Avatar
I have the following problem in RAC 2012...please see PDF's attached. The wall needs to follow the outline of the stair...part of the underside of the stair is on the exterior...how can I
1) add/enclose the stair with a angled wall - basically a wall that follows the stringer/stair to the next level2) the bottom of the stair is on the exterior/enclosed with plaster finish...How do I enclose the bottom of the stair with plywood/plaster to match existing?
Thanks
Edited on: Mon, Mar 4, 2013 at 1:04:34 AM
Mon, Mar 4, 2013 at 3:56:26 AM | How to create wall for angeled staircase -
4 Stars: 205 Votes
In that section/elevation view create a "Ref. Plane" then attach the wall to that ref. plane
Mon, Mar 11, 2013 at 7:10:57 PM | How to create wall for angeled staircase -
tectacoma
tectacoma Avatar
Thanks, I'll try that next.
Mon, Mar 11, 2013 at 7:43:24 PM | How to create wall for angeled staircase -
tectacoma
tectacoma Avatar
I tried but I'm getting ERROR message.."can't keep elements joined" see attached pix.
Any idea what I'm doing wrong?
Thanks
Mon, Mar 11, 2013 at 8:21:03 PM | How to create wall for angeled staircase -
tectacoma
tectacoma Avatar
Got it...here's how I did it in case anybody runs into the same issue
1. Draw reference plane in Elevation
2. Draw wall in floorplan
3. In Elevation pick wall - then click "Edit Profile" under Mode in the Modifying command
4. The wall will appear in magenta lines - Now you're able to edit the outline of the wall.
5. Finish
Trimming a wall intersected by an angled staircase
Tue, Nov 24, 2009 at 5:11:01 PM
Staircase help - winder staircase
Wed, Nov 28, 2007 at 4:31:48 PM
How to create Folded Plate Staircase
Wed, Dec 17, 2008 at 4:09:59 PM
Staircase not going to levels?
Mon, Mar 7, 2016 at 6:06:52 PM
New Stair Tag Family!
Tue, Nov 11, 2014 at 1:48:59 AM
Page generation time: 2.8722
