Forums >> Revit Building >> Technical Support >> same column component, different grafics
Sat, Mar 2, 2013 at 5:57:39 PM | same column component, different grafics
Warchitect
4 Stars: 5 Votes
So check this image. I have two columns, they are exactly the same, but they dosplay different. also one changes to show new, and the other was white, now, one is cut at a different plane or something. anyone got any clues? or is this just a bug.
Warc
Sun, Mar 3, 2013 at 7:23:20 AM | same column component, different grafics
coreed
coreed Avatar
4 Stars: 16 Votes
Let's see a 3D shot. Are they both at the same base level?
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sun, Mar 3, 2013 at 8:44:44 PM | same column component, different grafics
Warchitect
4 Stars: 5 Votes
Here you go. window tile!
Mon, Mar 4, 2013 at 3:44:17 AM | same column component, different grafics
4 Stars: 205 Votes
Do you have any "Plan Region" around that column?
Mon, Mar 4, 2013 at 6:26:08 AM | same column component, different grafics
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
The column might be attached to the roof...delete the column and place it again.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions.
Modeling component driven by host's parameters??
Wed, Nov 20, 2013 at 3:03:42 PM
READING FAMILIES VIA COMPONENT
Wed, Nov 19, 2014 at 9:49:21 AM
Constraining Structural Column Within a Revit Family
Fri, May 9, 2008 at 3:22:04 AM
DISPLAY COLUMN LABELS
Wed, Sep 8, 2010 at 3:53:41 AM
Column Capitals
Wed, Sep 18, 2019 at 8:39:07 AM
Page generation time: 2.0841
