Forums >> Revit Building >> Technical Support >> 3d views can not be change from shaded to hidden lines.
Sat, Mar 2, 2013 at 10:33:53 AM | 3d views can not be change from shaded to hidden lines.
BlueFairy
I tend to use my 3d views often to pan around my building.  I often go from hidden lines to shaded to wireframe but theres seems to be now way to do this now on revit 2013.  What happened?  what are the settings to fix this?
Sun, Mar 3, 2013 at 6:02:53 AM | 3d views can not be change from shaded to hidden lines.
4 Stars: 205 Votes
Maybe a graphic card issue... update drivers for video card... post some images please.
Mon, Mar 4, 2013 at 7:24:16 AM | 3d views can not be change from shaded to hidden lines.
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"but theres seems to be now way to do this now on revit 2013"
What do you mean theres no way to do it?  Are the options grayed out to change the visual style?  If they are do you have a view template applied?
Mon, Mar 4, 2013 at 9:00:40 AM | 3d views can not be change from shaded to hidden lines.
Good thought teafoe - they really messed up view templates in 2013.
Mon, Mar 4, 2013 at 11:00:03 AM | 3d views can not be change from shaded to hidden lines.
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Ya, maybe get rid of the view template property of the view <none>. View templates are really good and save a ton of time but they sure can cause confusion if you don't understand what they do and how they work (R 2013 only).
Lines showing through faces in shaded or hidden views
Sat, Apr 15, 2017 at 7:43:18 AM
Wireframe lines showing up in Shaded 3D View
Thu, Apr 2, 2009 at 11:36:35 AM
black lines
Tue, Jun 20, 2006 at 12:34:17 PM
Printing vector changes solid to hidden line, shaded areas don't show correctly
Mon, Apr 20, 2015 at 10:56:21 AM
Wall Hidden Lines and Object Styles
Tue, Jul 31, 2007 at 11:47:48 AM
Page generation time: 0.6688
