Forums >> Revit Building >> Technical Support >> Labels in title block literally gone in project
Fri, Mar 1, 2013 at 1:06:37 PM | Labels in title block literally gone in project
quinn
Few of the labels in one of our projects have dissapeared completly but the information is still there in the project parameters.
Example the date, client name etc gone in project burt when you edit the t.b. family they are there.
There is no question mark even available blue or red in the project.
We checked the shared parameters too and they are pathed to the correct text file.
We have tried loading in a new title block from other projects as well as the template they all have that information missing which makes me think the issue is inherent in the project.  We have tried adding new labels withe the same client name etc into tb then reloaded nothing still.
Edited on: Fri, Mar 1, 2013 at 5:42:03 PM
Fri, Mar 1, 2013 at 1:54:34 PM | Labels in title block literally gone in project
quinn
update - we discovered the project information button on the drawing bar is completly grayed out and we have no access to it.
Fri, Mar 1, 2013 at 2:46:16 PM | Labels in title block literally gone in project
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Shared parameter file is missing ?
Fri, Mar 1, 2013 at 5:41:20 PM | Labels in title block literally gone in project
quinn
The only way we could fix this issue is to transfer project standards from a different project and the project info tab came back and the titleblock fixed itself.  Still no clue how that happened has to be a bug.
Edited on: Fri, Mar 1, 2013 at 5:41:34 PM
Thu, Nov 20, 2014 at 7:17:34 AM | Labels in title block literally gone in project
selectstructural
I came in this morning to the same issue.  It was there yesterday and not this morning.  Titleblock is working fine in other drawings just not this one.  all the text labels are whited out.  you can hover over the label and see something should be there but nothing.
when i open the titleblock same thing you can hover over it and click on it all the properties are correct just nothing shows up.
Jennifer Arnold
jennifer@selectstructural.com
Thu, Nov 20, 2014 at 8:00:08 AM | Labels in title block literally gone in project
Audit the file then if still a problem, create a new sheet and move the views to that then delete the bad sheet.
Thu, Nov 20, 2014 at 8:22:22 AM | Labels in title block literally gone in project
selectstructural
the labels use text font arial narrow.  when i change that to just arial all the label show back up.  Any ideas why this would happen.  I've used the font before.
btw audit didnt do anything.
Thanks
Jennifer Arnold
Title Block labels
Sun, Apr 8, 2007 at 10:04:03 PM
Title Block Labels
Wed, Feb 14, 2007 at 11:52:49 AM
Title Labels [ 1 2 ]
Sat, Jun 29, 2013 at 12:54:18 PM
16
Title block labels not appearing in projct
Thu, Aug 22, 2013 at 5:36:25 PM
Title Block Labels
Thu, Aug 21, 2008 at 1:14:02 PM
Page generation time: 0.5172
