Forums >> Revit Building >> Technical Support >> Reloading Linked DWG's
Fri, Jan 27, 2006 at 8:25:43 AM | Reloading Linked DWG's
elvis
Hi all, when I do reload a linked dwg, i resets somehow all the visibility settings i did make. example, it sets all the colored layers back,instead of all black, or resets all queried layers into hidden. is their a way to reload or update dwg links without having to set all the visibility settings over and over again. E.
Sat, Jan 28, 2006 at 5:51:05 PM | RE: Reloading Linked DWG's
eldados
eldados Avatar
4.5 Stars: 8 Votes
I guess you are talking about the visibility settings of your linked dwg... you will have to make the changes in the dwg before you reload, otherwise how will Revit know what settings yu want to keep?
Integrator
KarelCAD
Reloading Linked Files - Lost Sheet Views
Tue, Aug 23, 2011 at 8:52:01 AM
Reloading linked dwg
Tue, Apr 29, 2008 at 8:08:23 AM
Dimensioning with linked DWG files
Sat, Nov 12, 2011 at 4:20:06 PM
Rotate linked DWG for elevation drawing
Thu, Aug 17, 2006 at 9:59:28 AM
Retain visibility if the linked dwg's are updated outside REVIT
Fri, Nov 9, 2007 at 10:14:52 AM
Page generation time: 0.3880
