Forums >> Revit Building >> Tips & Tricks >> The Stair Below
Thu, Feb 28, 2013 at 3:47:43 PM | The Stair Below
rwood27
Ok, so stairs going up, fine they cut off nicely.  Stairs going down not so much.  The stairs below have a turn so they don't track with the stair going up.  View depth is set to current floor (0') but you still see the whole stair going down.  What's the deal?
Screen shot attached.
Fri, Mar 1, 2013 at 7:58:21 AM | The Stair Below
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Do you have an underlay on? Is the floor above actually covering the stair below?
Fri, Mar 1, 2013 at 9:03:51 AM | The Stair Below
rwood27
Nope, no underlay on.  Stairs do overlap but as you can see in the image, the stair going down has a 90 deg turn in it as it gets toward the bottom.  I don't want to see the stair down there because it looks confusing.
Can not swap out one stair family for another
Thu, Sep 19, 2013 at 12:24:19 PM
How can I create a split stair without multiple and separate stair components?
Tue, Jan 5, 2016 at 5:32:53 AM
Stair Nosing
Fri, Dec 2, 2016 at 2:01:57 PM
Simple Stair Nosing error
Thu, Mar 5, 2015 at 9:15:24 PM
Stair Showing Below Mezz Slab
Fri, Jan 27, 2012 at 8:21:10 AM
Page generation time: 0.7062
