18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> DOOR TAG QUESTION
I am using Revit Architecture 2013. Is it possible to have Revit identify and tag a door with its size? For example 3068 on the plan view near the door (see attached) for a 3' wide by 6'-8" door. This metthod of door callouts would replace the door schedule. Is it also possible to do a similar callout for windows? Example 3050 for a 3' wide by 5' tall window, placed near the window on plan.
Thanks,
Rob
From a previous post http://www.dgcad.com/downloads/CADCLIP-WINDOW-AND-DOOR-TAGS.wmv
Thanks! I couldnt open the link. It takes me to a page where someone can login.
Take care,
Rob
Type that link in - I must have associated the wrong link with the text.
Thanks! I will give it a try... I appreciate your help.
Take care,
Rob
Thanks! That worked great! I just had to wait for the video to download. I appreciate your help. I am going to make some door and window tags now.
Thanks again,
Rob
I have another question about the tags: I got the tag to work but it shows 3'-0" 6'-8" for my 3068 door. What format method is best to use to get the tag to read 3068?
Thanks!
Rob
Instead of using the parameters Width and Height the best way is use 'Type Name'.
Give the name as per your rquired format.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions. |
Thanks! I will try using "Type Name". I appreciate your help.
Take care,
Rob
Create & reference door tag parametrics |
Thu, Nov 8, 2007 at 2:24:44 PM
Door Tag Locations. |
Wed, Aug 24, 2011 at 12:48:11 PM
Residential Door Tag |
Fri, Jul 7, 2006 at 8:18:54 PM
door tag exposing the door-width |
Wed, Sep 16, 2009 at 4:52:04 PM
Door Tag Parameter-Need it to be the door opening number, not the door type..... |
Thu, May 7, 2009 at 4:09:39 PM
