22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> A possible crash? (v. 2012)
29 Posts No Rating |
My project partner and I have been having issues with Revit in the last couple of days and I want to find out what it could indicate. In the last two days, we've had a couple of surprises such as: The interior elevations are not completely showing a "hidden" view. Structural column bump outs and sinks are showing through the cabs surrounding them. Vinyl Base has a gyp. bd. surface pattern. They print correctly, but are not showing on the screen correctly. Most recently, my project browser changed the sorting order. I've been able to re-sort and have all the drawings needed, albeit in a different order than the office standard. I have checked into the obvious check boxes and so forth, but would like to know if anybody else has ever had this experience, if so, what eventually happened? Is this a precursor to a crash? Any advice is appreciated in advance.
first off do you have DWG links in your file? perhaps with proxies in them....
if not you need to send that project file to autodesk and have a software engineer take a look. they are pretty good at finding corruption in a file.
Crash!!!! |
Thu, May 5, 2011 at 4:09:10 PM
crash n burn |
Thu, Nov 24, 2011 at 8:07:41 AM
Revit 2012 Crash from Print |
Fri, Dec 21, 2012 at 10:15:56 AM
crash recovery |
Thu, Apr 23, 2009 at 7:02:48 PM
Revit crash when dimensioning |
Thu, Jul 15, 2010 at 7:38:36 AM
11
