18 Users Online (16 Members):
Forums >> Revit Structure >> Technical Support >> intersecting inner walls with slanting outer walls
10 Posts No Rating |
I have a problem with cleaning up and intersecting inside walls, with outside slanting walls.
This problem has been eating me up, so i hope someone can help?!
Look at the pic to understand.
Thanks
You'll have to EDIT those walls PROFILE to do what you want....
It seems to work, only i can't snap the profile on to the slanting wall, getting them to intersect. ?
It doesn't look like you have a wall applied to the exterior yet. You should be able to use the pick lines tool to grab the slanted profile.
Both suggestions worked nicely! Thanks alot!
Inner walls overslaping outer walls. |
Sun, Dec 14, 2014 at 4:58:35 PM
intersecting elements problem |
Tue, Sep 15, 2009 at 11:25:17 AM
Slanting walls along a beam |
Wed, Mar 29, 2017 at 4:07:54 PM
Building 20+ story skyscraper/highrise how do make outer structure? |
Mon, Mar 28, 2011 at 10:27:03 PM
Join walls command for a group. Issue |
Sun, May 13, 2018 at 11:06:02 PM
