Forums >> Revit Building >> Technical Support >> Door Number on two sides of Door Schedule
Tue, Feb 26, 2013 at 9:55:57 AM | Door Number on two sides of Door Schedule
palladio1234
5 Stars: 3 Votes
Is it possible to have the door number show up twice in the same row on a door schedule?  I am trying to put a door number on the very left and one on the very right all in the same horizontal row to make it easier to follow the schedule.
Edited on: Tue, Feb 26, 2013 at 9:56:37 AM
Tue, Feb 26, 2013 at 10:02:28 AM | Door Number on two sides of Door Schedule
Easy,
Create a new schedule field, calculated value, and set it = door number.
Tue, Feb 26, 2013 at 10:11:22 AM | Door Number on two sides of Door Schedule
palladio1234
5 Stars: 3 Votes
WWHub thanks for the quick response.
I keep getting "inconsistent units" error.
I have formaul set to "Mark"
I have name set to "Door Number 2"
Disipline is set to "Common"
Type is set to "Number"
I think I am doing something wrong with formula?
Tue, Feb 26, 2013 at 10:13:07 AM | Door Number on two sides of Door Schedule
palladio1234
5 Stars: 3 Votes
Well I set type to "text" and it worked!
Thanks for your help!
Tue, Feb 26, 2013 at 10:14:18 AM | Door Number on two sides of Door Schedule
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
This can easily be done.
In the door Schedule properties Dialog box on the Fields Tab click Calculated Value.
Name the Field 'Mark 2', Leave Formula Checked, change the Type to Text, in the Formula field click the little parameter button (3 little dots) then clcik the 'Mark' field from the list. Click OK and that should effectively duplicate that field in your schedule.
See Attached.
WW you're to quick for me : )  . . . . I can't type and paste that fast !
Edited on: Tue, Feb 26, 2013 at 10:16:13 AM
Tue, Feb 26, 2013 at 10:17:17 AM | Door Number on two sides of Door Schedule
palladio1234
5 Stars: 3 Votes
Thank you dgcad & WWHub for the answers! Learned something new today : )
Door Tag Parameter-Need it to be the door opening number, not the door type.....
Thu, May 7, 2009 at 4:09:39 PM
Door Schedule
Tue, Jun 12, 2007 at 7:29:31 AM
Door Schedule
Fri, Aug 17, 2012 at 7:07:50 AM
Calculated Value - Door Schedule Work Around?
Mon, May 18, 2015 at 12:56:02 AM
Can't input information into door schedule manually
Tue, Jan 20, 2009 at 6:12:54 PM
Page generation time: 0.4435
