Forums >> Revit Building >> Technical Support >> ACIS Import
Thu, Jan 26, 2006 at 11:35:13 AM | ACIS Import
daveg
I have been working on a form in 3ds max 8 and am trying to get the form into Revit 8.1 so that I can use buildingmaker on the form. I can import it as a dwg but as I created an editable mesh in max (which is closed forming what would seem a solid object), I cannot use this. Is there a way to convert it to an ACIS solid without having to get some additional conversion plugin? If there was a way to take it through AutoCAD (as it likes ACIS objects then that would be fab!) Cheers
Thu, Jan 26, 2006 at 11:40:56 AM | RE: ACIS Import
TomDorner
4.5 Stars: 25 Votes
Not sure on the ACIS solids issue, but what you probably want to do in any case is insert either the 3D dwg or ACIS into a massing fimily, then insert the massing family into your Revit project. You can then use the custom massing family to create floors, cwalls, walls, roofs etc via the building maker.
Tom
www.reviteer.com   http://twitter.com/Reviteer
Thu, Jan 26, 2006 at 11:47:15 AM | RE: ACIS Import
daveg
Thanks... The problem with this is that revit doesnt recognise the model produced from max (an editable mesh) and therefore whilst you can import the geometry into revit, the building maker tools dont like form (ie you can only select one or two faces on the object whilst it displays the whole form as apparently solid). Apparantly if it reads an ACIS solid then it can do a lot more with it (I get the error: "Mass contains only mesh geometry, which can’t be used to compute floor area faces, volume, or surface area."Winking
Thu, Jan 26, 2006 at 11:53:32 AM | RE: ACIS Import
TomDorner
4.5 Stars: 25 Votes
I don't use Max so I can't help you. You may want to post the question on AUGI (www.augi.com) as there are more experienced users on that forum and some of them are doing the more advanced modeling in other programs like Max/Viz, Maya, SketchUp etc.
Tom
Converting AutoCAD ACIS Objects (3D Solid) to Polymesh Objects
Fri, Oct 12, 2012 at 7:31:58 AM
CAD exporting RE:What is an ACIS solid
Fri, Jan 4, 2008 at 4:22:43 PM
NURBS import
Mon, Nov 28, 2005 at 10:33:40 AM
ACIS export problem and Hi from France
Mon, May 30, 2011 at 10:10:04 AM
Hide/isolate in view versus in print
Sun, Mar 22, 2009 at 4:01:20 PM
Page generation time: 5.1411
