Forums >> Revit Building >> Technical Support >> How to edit Host Layer Line Styles
Fri, Feb 22, 2013 at 4:08:47 PM | How to edit Host Layer Line Styles
ALICEHER
Is there a way I can change the host layer line styles line weight throughout the project? I can use VV to change it in a view; however, I would like to change their line weights throughout the project.
Thanks,
Sat, Feb 23, 2013 at 6:19:06 AM | How to edit Host Layer Line Styles
4 Stars: 205 Votes
"View Templates" are the key, check your HELP menu
Sat, Feb 23, 2013 at 8:55:42 AM | How to edit Host Layer Line Styles
I'm not sure what you men by "host layer".  VG sets view only but under the manage tab, option styles you can set category VG for the entire project.  You should set this in your project template but you can modify it by project if needed.
Mon, Feb 25, 2013 at 11:00:23 AM | How to edit Host Layer Line Styles
ALICEHER
I'm trying to change the line weight of specific "functions" within my wall such as "structure", "substrate", etc. I can override them with VV; however, I would like to change them in every view, not just one. At worst, I can create View Templates to do this. I was just hoping there was another way.
line styles in families
Tue, Mar 10, 2015 at 6:54:38 PM
Removing Line Styles
Mon, May 8, 2017 at 2:21:04 PM
Associating Line styles with patterns
Tue, Sep 18, 2012 at 11:30:05 AM
Deleting Line Styles
Tue, Aug 5, 2014 at 2:57:29 PM
Line / Layer name information.
Tue, Jul 24, 2007 at 3:00:43 PM
Page generation time: 0.5487
