Forums >> Revit Building >> Technical Support >> stair nosing
Thu, Jan 26, 2006 at 10:53:56 AM | stair nosing
THG2005
1 Stars: 1 Votes
wehn i give a nosing profile why does it change my treads from slanted to straight? is there a way to have a square nosing profile with slanted treads?
Sun, Jan 29, 2006 at 11:05:25 PM | RE: stair nosing
eldados
eldados Avatar
4.5 Stars: 8 Votes
yes, there should be no difference, I can have a profile with straight or slanted...
Integrator
KarelCAD
Mon, Jan 30, 2006 at 2:16:45 PM | RE: stair nosing
THG2005
1 Stars: 1 Votes
anytime i give the tread a profile it changes the riser to straight. it still says slanted but the appearance is obviously is staright. could someone please help to fix this? what profiles are you using? i am thinking it may be the profile i am using was created incorrectly and is causing this problem.
Stair Nosing
Fri, Dec 2, 2016 at 2:01:57 PM
Stair Nosing Profile Help
Thu, Feb 21, 2008 at 8:29:59 AM
Monolithic Stair Radius nosing?
Fri, Jan 30, 2009 at 2:10:43 PM
Simple Stair Nosing error
Thu, Mar 5, 2015 at 9:15:24 PM
Stair nosing
Mon, Jan 23, 2012 at 2:27:10 PM
Page generation time: 0.6478
