Forums >> Revit Building >> Technical Support >> 360 cloud rendering the lights like garbage
Fri, Feb 22, 2013 at 11:24:13 AM | 360 cloud rendering the lights like garbage
andy777bennett
when I render in the cloud many kinds of lights have a rectangle blocking them. sometimes its black, or brown, or white. anyone know why?
Fri, Feb 22, 2013 at 11:26:17 AM | 360 cloud rendering the lights like garbage
andy777bennett
using 2013 sorry
Fri, Feb 22, 2013 at 12:37:21 PM | 360 cloud rendering the lights like garbage
The problem is your light suface material - lens and bulb glass if you have those as well.  If it is a solid (non transparent material), it will block your light.  In addition, you will not see it as a light source unless you set the buldb material or the lens to glow.
Correct these materials in the project.
Fri, Feb 22, 2013 at 12:47:51 PM | 360 cloud rendering the lights like garbage
andy777bennett
i wouldn't be mad if there was something in the way. i would just delete whatever is in the way. all of these images are using the same lights. some are black even. The last one was rendered on my computer.
Fri, Feb 22, 2013 at 12:48:59 PM | 360 cloud rendering the lights like garbage
andy777bennett
sorry here is the middle one that has black... i am failing at post editing today
Edited on: Fri, Feb 22, 2013 at 12:51:21 PM
Fri, Feb 22, 2013 at 12:52:07 PM | 360 cloud rendering the lights like garbage
andy777bennett
it isnt letting my upload the other pic... you get the idea
Edited on: Fri, Feb 22, 2013 at 12:52:59 PM
Fri, Feb 22, 2013 at 12:56:52 PM | 360 cloud rendering the lights like garbage
Your right - your lights appear to be correct. I did not see your partial view below which I assume is a Revit coarse, render check.
I don't use 360 so I don't know if it has other special problems.  Recheck your light settings for that hall view .
Run a test with daylight off.
Tue, Feb 26, 2013 at 3:20:23 PM | 360 cloud rendering the lights like garbage
andy777bennett
I may have found the problem. I do not have time to test and confirm but in switching around the light source definition for the lights the cloud started rendering them right. So I do not know exactly which light sourch definition shapes yeild the proper result, but if others are having this problem, that should be the first thing you try.
Cloud Rendering - Lighting
Fri, May 10, 2013 at 5:03:57 PM
Interior lights in Cloud renderings
Mon, Nov 9, 2015 at 2:41:26 PM
Autodesk 360 cloud
Fri, Feb 22, 2013 at 11:21:56 AM
Autodesk Cloud - Buying more Cloud Units [ 1 2 ]
Mon, Apr 15, 2013 at 8:37:28 AM
17
Cloud Rendering - panoramic image
Sat, Jan 26, 2013 at 5:50:19 AM
Page generation time: 6.4374
