Forums >> Revit Building >> Technical Support >> How do I remove faceting from imported 3d objects?
Thu, Feb 21, 2013 at 5:15:57 PM | How do I remove faceting from imported 3d objects?
ihearthank
I imported some 3D cad furniture objects into Revit 2013. They came in as 3D objects, but the surfaces are all faceted.
thanks!
Fri, Feb 22, 2013 at 3:55:44 AM | How do I remove faceting from imported 3d objects?
4 Stars: 205 Votes
You Can't, you have to do that in CAD and not Revit.
Fri, Feb 22, 2013 at 7:26:40 AM | How do I remove faceting from imported 3d objects?
Faceting is a problem in non-rendered views.  For items like that, we use 2 1/2D families.  The 3D only shows up in 3D views, for plans and elevations, the family has symbollic linework.
rendering imported objects
Tue, Mar 10, 2009 at 2:23:18 PM
Remove hidden CAD imports
Thu, Nov 6, 2008 at 9:32:16 AM
Remove Constraints from Deleted Objects
Tue, Feb 26, 2008 at 4:44:57 PM
rendering imported dxf objects?
Thu, Aug 17, 2006 at 10:32:49 PM
please help- tried everything to get objects to accept material...
Thu, Apr 16, 2009 at 12:45:04 AM
Page generation time: 0.5667
