Forums >> Revit Building >> Technical Support >> View Tag - want to add a second line of text
Thu, Feb 21, 2013 at 4:10:07 PM | View Tag - want to add a second line of text
ShawnMosch
I am a newer user to Revit, and i am using 2013.  We want to add a second line of text to our View Tags for our Interior Elevations for a current project, and I am SURE that there is a wa to edit it to make this possible but I cannot figure it out.
I attached an example of what we want to be able to do . . . this example is from a recent project we did in AutoCAD.  See how we have the second line of text under the view tag for the SIM note . . . how can we do that with Revit?  Currently we are just placing text under the View Tag, but then if we need to move things around you have to remember to grab both the view tag and the text.
Thanks!
Thu, Feb 21, 2013 at 4:16:11 PM | View Tag - want to add a second line of text
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Edit the view tag family and add a text parameter to it in that location.
Fri, Feb 22, 2013 at 3:46:17 PM | View Tag - want to add a second line of text
ShawnMosch
I am in the edit funtion right now, and I don't see where I would be able to add that second line of text.
I have an "Edit Label" with parameters but none of the parameters are for an extra line of text.
Like I said, I am new to Revit . . . just took a basic training course and now and just using it on a daily basis for the first time.
Sat, Feb 23, 2013 at 8:30:43 AM | View Tag - want to add a second line of text
Tag parameters can only be shared parameters.  Looks like this is your next assignment.
Read your HELp on how to create and use these special parameters.  Then you can fix your level family.
How do I create a Room Tag that has a text field that I can add comments too?
Mon, Nov 20, 2017 at 4:22:21 PM
Adding Optional Text Field to Keynote Tag
Thu, Nov 13, 2008 at 8:52:47 AM
Control Line in View Title Tag
Mon, Jun 11, 2018 at 7:45:48 AM
Detail Line with Text & Arrow
Mon, Sep 28, 2015 at 9:54:43 AM
Text as a yes/no parameter in a Tag
Wed, Sep 29, 2010 at 11:02:06 AM
Page generation time: 1.0334
