28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> Change of Infornation on a Call out Ref and Easting/Northings on a Topo survey
2 Posts No Rating |
Two Questions as I am new to using Revit..
The first is on a call out reference for a section view of a Top survey, as the section view is to long the section is in two parts, however the call out refernce header shows an in correct reference number. how can i modify the text in the call our reference header, and the additional text ie the original dotted lines behind it.
the second question is i need to show some info on a topo survey i have the exact eastings and northings, but how can use the exact figures to plot a reference on topo drawing.
Thanks Paul
Question 2: It's in your HELP. Always look there first
http://wikihelp.autodesk.com/Revit/enu/2012/Help/Revit_User's_Guide/0140-Prelimin140/0175-Site_Des175/0187-Property187
2 Posts No Rating |
Thanks I have tried the method from the Help point, but still no joy, to give a clearer picture of what im trying to do I have been given some points for example eastings/northings (426419.495/564261.340) i need to plot them on a imported topo survey. how can i find the point of this location on the survey and plot it.
Again, in your HELP
http://wikihelp.autodesk.com/search?source=help&product=Revit&q=coordinates&language=ENU&version=2012
http://wikihelp.autodesk.com/Revit/enu/2012/Help/Revit_User's_Guide/0140-Prelimin140/0170-Project_170/0171-Specifyi171
topo survey AutoCAD to Revit |
Thu, Feb 26, 2009 at 11:45:41 AM
autoCAD Survey Plans to 3D Topo |
Fri, Aug 1, 2008 at 4:12:58 AM
Topo Surface help |
Wed, Mar 17, 2010 at 5:50:48 AM
how to change defined ref planes in a family |
Mon, Apr 18, 2011 at 2:07:00 AM
Modeling Topo After Building |
Fri, Jun 24, 2016 at 11:35:23 AM
