Forums >> Revit Building >> Technical Support >> Sloped Beam Connection
Tue, Feb 19, 2013 at 2:56:13 PM | Sloped Beam Connection
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I have a structure where the sloped beams make up the roofing structure.  I have my H.P level set and my first beam runs at -10" to 0" the next runs 0" to -10" creating a ridge the next bay should be -10" to 0" HOWEVER when I try to put in that beam connected to the last beam it shoots it off into the last grid shrinking the second beam and screwing up the elevations.  See the attached images for clarification.  Any ideas how I can get the 2nd and 3rd beams to connect without it shooting the third beam way
REVIT 2013
Edited on: Wed, Feb 20, 2013 at 8:07:21 AM
Thu, Feb 21, 2013 at 11:13:15 AM | Sloped Beam Connection
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I placed a column line in at the splice locations (you could also use a reference plance) and after it shot the sloped beam out to nowhere I dragged the end past the splice point (the shape handle not the other one) and the cut the beam to the splice grid line and it works!
Need Help on Sloped Beam-Column Connection
Fri, Apr 29, 2016 at 1:50:43 PM
Steel Beam to Beam Connection
Fri, Jun 18, 2010 at 1:54:36 PM
Sloped Beam?
Thu, Dec 15, 2005 at 3:38:36 PM
Cut a sloped beam
Fri, May 11, 2012 at 3:48:19 AM
Steel beam connection with structural wall
Fri, Mar 1, 2013 at 9:06:41 AM
Page generation time: 0.5256
