15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> pick walls method
Can anyone tell what's the use of the Pick Walls tool for drawing floors or ceilings? And why can't this tool pick the Exterior Face lines instead?
Many thanks.
Revit Architecture 2013
ArchiCAD 16 Win
Windows 7 Enterprise 64-bit |
From the help flyout: Add sketch lines based on existing walls. Sketch lines created using this tool are automatically constrained to the walls.
"why can't this tool pick the Exterior Face lines instead" Ceiling are created INSIDE of walls not the exterior of walls. If you have an exterior face of a wall you need to use for some reason just use the Pick Lines tool.
Remember that you also have pick lines. Be aware that constraints are good and sometimes bad.
Example - the GOOD: A ceiling is constrained to a wall. You move the wall and the ceiling size adjusts accordingly.
Example - the BAD: A ceiling sketch is constrained to a wall. You later split the wall and jog it. Gues what! Your ceiling completely goes away and your mechanical and electrical engineers are yelling at you because they now lose their hosted objects. The Fix, you have to edit the ceiling first and get rid of that constraint.
good point.
ArchiCAD 16 Win
pick walls to create floor |
Tue, Apr 3, 2012 at 12:04:02 PM
OPenings through multiple walls? |
Mon, May 24, 2010 at 4:48:54 PM
3d edge pick cancels previous pick. |
Thu, Feb 9, 2017 at 5:32:26 PM
floor by pick wall |
Fri, Feb 26, 2010 at 10:25:54 AM
Changing wall finishing thickness without having to align it again |
Tue, Jul 3, 2018 at 10:42:11 AM
