Forums >> Revit Structure >> Technical Support >> Joining Beams
Tue, Feb 19, 2013 at 9:01:16 AM | Joining Beams
havoc1
I am using Revit 2013 and can join beams, already in revit, at corners (45 degree angle) however I created a new family beam and am having trouble joining them at the corners. I have already tried the join geometry and join beams commands.
Any and all help is greatly appreciated.
Danny Murray
Edited on: Tue, Feb 19, 2013 at 9:38:08 AM
Tue, Feb 19, 2013 at 9:50:06 AM | Joining Beams
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You created a beam family?  You haven't really given us enough information.  What sort of beam (can you attach the family), what is happening when you try to join them at the corners? Can you attach some images of your problem?
BEAMS JOINING COLUMNS problem
Tue, Jun 30, 2015 at 7:41:51 AM
joining two beams
Fri, Jul 6, 2007 at 12:03:10 PM
Concrete beams joining at expansion joint
Tue, Feb 8, 2011 at 2:04:44 PM
Concrete Beam Not Joining?
Fri, Jul 15, 2011 at 10:59:14 AM
Joining beams to walls and floors
Thu, Jan 15, 2009 at 9:00:36 AM
Page generation time: 0.7263
