Forums >> Revit Systems >> Technical Support >> Revit MEP 2013 - One space says its there but none to be found
Mon, Feb 18, 2013 at 11:52:28 AM | Revit MEP 2013 - One space says its there but none to be found
heinzk1
I have an 2013 MEP Central file and have shaded all the space to have them show up.  We have found one space is not showing up.  It lists in the System browser and it shows up in a Room schedule which I created.  The room shows area / perimeter / unbound height etc except volume.  The volume of the room is Zero.  When having Revit show me the space it says no good views found. I have made sure that the space has not been hidden.
I have checked sections and all floor plans.
So the question is how do I delete the space so I can place another back in?
If I place a space in, it tells me there is one already there.
Sincerely,
Ken
Mon, Feb 18, 2013 at 12:22:48 PM | Revit MEP 2013 - One space says its there but none to be found
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
If it shows up in the room schedule you can delete it right from the schedule and that is the best way to do it.
Exporting from Revit 2013 to Autocad MEP 2010 while retaining intelligent object
Sat, Dec 7, 2013 at 12:08:38 AM
MEP TABS IN 2013 - WHERE?
Thu, Jul 19, 2012 at 11:03:35 AM
Revit MEP 2013 - Electrical homeruns not updating
Wed, Feb 13, 2013 at 10:33:51 AM
Reporting Space / Room Names and number in schedules
Mon, Oct 15, 2012 at 8:15:25 AM
MEP + Unoccupied Space??
Fri, Feb 19, 2010 at 2:53:14 AM
Page generation time: 4.5145
