Forums >> Revit Structure >> Technical Support >> Question About Model Pattern
Mon, Feb 18, 2013 at 11:49:37 AM | Question About Model Pattern
droberts25
I have a shell building that I am trying to add King Size brick too.  I want this to show up as a model pattern so it will show up in 3D view, elevation, ect...  I know how to properly make a model pattern file in note pad so revit will read it.  The issue i am having is that everytime i try to create a new model pattern in revit and assign the .pat file to the new model pattern in revit a dialogue box appears saying "No "Model" type patterns found".  I know that i have the model type stated in the notepad .pat file.>;%TYPE=MODEL.  Yet it pops up with this error box in Revit.  Would like to know if this has happened to others and how to resolve this.
Thanks.
Mon, Feb 18, 2013 at 12:20:19 PM | Question About Model Pattern
You have:
>;%TYPE=MODEL
and that needs to be:
;%TYPE=MODEL
on its own line.
Edited on: Mon, Feb 18, 2013 at 12:21:00 PM
Mon, Feb 18, 2013 at 12:51:08 PM | Question About Model Pattern
droberts25
Im sorry that is a typo on my part. I do have the ;%TYPE=MODEL in the text correctly
Mon, Feb 18, 2013 at 1:44:41 PM | Question About Model Pattern
Why not post your text?  At least the beginning.
I believe this line had to be right under the title line and before anything else.
I also don't remember if this error pops up if the file is incorrect elsewhere....
Mon, Feb 18, 2013 at 2:31:10 PM | Question About Model Pattern
droberts25
*Brick
;%TYPE=MODEL
0, 0, 0, 0, 9
90, 0, 0, 2.75, 0, 4.5, -4.5
Mon, Feb 18, 2013 at 2:52:52 PM | Question About Model Pattern
Everything appears to be correct.  Are you sure this is a simple txt file?
Also ... I wonder - Is this a unique name?  Just brick?  Could you already have a 2D pattern for Brick?????  Just wondering if Revit doesn't like this.  Change that and see if it does work.
Mon, Feb 18, 2013 at 3:08:47 PM | Question About Model Pattern
droberts25
Yes this is a simple text format, i have double checked.  The name brick is not unique and i have even tried labelling it in different ways, still recieving the same error message.
Tue, Feb 19, 2013 at 2:22:11 PM | Question About Model Pattern
droberts25
Nevermind, situation resolved, found the solution and rolling on now.
Tue, Feb 19, 2013 at 2:40:21 PM | Question About Model Pattern
Please always post what the solution was so that others may learn.
Floor Model Pattern - Model option greyed out
Fri, Mar 3, 2017 at 10:11:12 AM
Floor pattern not showing up when the pattern is model pattern
Fri, Nov 3, 2023 at 9:11:59 PM
Model pattern override
Wed, Nov 10, 2010 at 3:50:54 PM
Model Cut Pattern?
Wed, Jan 30, 2013 at 12:16:11 AM
Editing Model Patterns...
Mon, Jan 4, 2010 at 12:56:50 PM
Page generation time: 0.6320
