Forums >> Revit Structure >> Technical Support >> top & bottom plates with wall framing extensions
Mon, Feb 18, 2013 at 11:02:36 AM | top & bottom plates with wall framing extensions
dmiller226
I'm still on the process of getting this all figured out but the main problems I'm running into with the wall framing is where the top & bottom plates are extending past the wall corners.
using Revit 2013.
What am I missing here?
Thank in advance
Mon, Feb 18, 2013 at 12:20:17 PM | top & bottom plates with wall framing extensions
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
How did you put the top and bottom plates in? Are they sweeps that are a part of the wall structure?  Did you try using the wall joins command and change it from Butt to Miter?
Mon, Feb 18, 2013 at 1:10:42 PM | top & bottom plates with wall framing extensions
dmiller226
The t & b plates are part of the wall extension structure.
Structural wall.
The corners are the default
Mon, Feb 18, 2013 at 1:31:56 PM | top & bottom plates with wall framing extensions
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Did you try using the wall join command and the miter as I suggested?  Do you have a setback set in the Wall Sweep dialog box? Attach a file with your wall if none of these help so I can look into it further.
Edited on: Mon, Feb 18, 2013 at 1:40:33 PM
Mon, Feb 18, 2013 at 3:59:07 PM | top & bottom plates with wall framing extensions
dmiller226
Trying to creat a 2mb files is seeming hard for me than it should be I think.  Still working on it a file to upload.
Tue, Feb 19, 2013 at 11:10:48 AM | top & bottom plates with wall framing extensions
dmiller226
OK,  I'm not having any luck pulling the wall type into a file that is 2 mb or less.  Any guidance?
Thanks
Tue, Feb 19, 2013 at 11:17:22 AM | top & bottom plates with wall framing extensions
Open a copy of your file then delete everything except your two walls.  Also all views, schedules, legends then purge all.
Tue, Feb 19, 2013 at 11:21:40 AM | top & bottom plates with wall framing extensions
dmiller226
wil do
Edited on: Tue, Feb 19, 2013 at 11:22:30 AM
Tue, Feb 19, 2013 at 11:32:00 AM | top & bottom plates with wall framing extensions
dmiller226
Here we go.  Still a learning curve for me where everything is.  Didn't realize there was a purge in it or I'd had that done yesterday.
I find it's holding the plates short or extending them the same distance past the corners
Thanks
Tue, Feb 19, 2013 at 12:30:12 PM | top & bottom plates with wall framing extensions
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
The wall types that you have in the attached file do not have any sweeps in them. I have attached the same file with a 2x4 double top plate sweep applied to it.  The edges clean up together.
Tue, Feb 19, 2013 at 12:54:13 PM | top & bottom plates with wall framing extensions
#11
dmiller226
OK, So I'm still at a little bit of a loss.  Did you apply the sweep after you created the framing?  In what you'd sent me it seems like the top plates & the wall are one entity rather than the framing being seperate from the wall.
Tue, Feb 19, 2013 at 1:17:58 PM | top & bottom plates with wall framing extensions
#12
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
The plates are a part of the wall.  Edit the wall, edit the structure, switch the view in the Edit Assembly dialog box to Section and under sweeps you can add them to your wall assembly so they are all one part.  Are you really going to show ALL of the framing in your project?  That is probably advised againt.  You can just use details items in sections.
Tue, Feb 19, 2013 at 1:30:07 PM | top & bottom plates with wall framing extensions
#13
dmiller226
I don't know what's with my dbl. posts, strange.
No not going to show all the framing, just trying to figure it all out. I would just like to get as good at Revit as I am with AutoCAD.
However we do some MTL. stud work where I put together shop drawings and I'm just trying different things.
Wood Framing - add top & bottom plates to wall family?
Mon, Jan 19, 2009 at 12:22:00 AM
Framing Plates
Mon, Dec 14, 2009 at 8:25:13 PM
Stair Handrail Extensions
Fri, Apr 11, 2008 at 10:48:31 AM
wood framing plan
Wed, Dec 31, 2014 at 9:10:12 PM
Residential Foudation
Mon, Dec 13, 2010 at 12:41:08 PM
Page generation time: 0.9020
